Old 02-20-2013, 09:25 PM
Ranger01 Ranger01 is offline
Default 97 mountaineer battery womt charge!!!
Alright so my 97 mountaineer v8 5.0 isn't charging and I'm stumped!
First started when I was driving and the battery light flickered and then the gauge starting dropping so I shy everything off and kept driving and it went back to normal and then when you would come to a stop it would go down a little till you hit the gas.
I immediately figure alternator so I put another on it. Had it tested at the parts store first and tested good. Put it in and still no charge. The yellow wire is reading 8.6 ( the voltage the battery has in it) and the green one is ready a steady 11.6 and the big wire on the alternator going to the starter is reading 11.6
I checked all the fuses and all are good. I even changed out the battery light bulb in the cluster. I am stumped. I took the alternator back off and tested it again and still tests good
Any input would be appreciated. Thanks guys
2001 3.0 V6 Automatic "Police Interceptor"
4x4 Off-Road
3" Body Lift
Belltech 6400 Shackles
JBA Headers
LOKRITE Locker
COBRA disc conversion
Old 02-20-2013, 09:31 PM
Spidey2011 Spidey2011 is offline
Default Re: 97 mountaineer battery womt charge!!!
First thought is the battery, but it sounds like it could be your belt tension. My Dad had a similar problem with his F250. Turned out his belt was worn and was slipping on the alternator pulley. It would sputter until you revved it up. Worth a shot, anyway.
Old 02-20-2013, 09:37 PM
Put a new battery in It also forgot to mention and the tensioner is tight no problems there
4x4 Off-Road
3" Body Lift
JBA Headers
LOKRITE Locker
Old 02-20-2013, 09:39 PM
Could the belt be worn?
Old 02-20-2013, 09:40 PM
Belt is good also I believe it's wiring some where
4x4 Off-Road
3" Body Lift
JBA Headers
LOKRITE Locker
Old 02-20-2013, 09:41 PM
Then you probably have a loose or broken wire somewhere. I had one in my Dish truck that took a bunch of trips into the dealer to find. Start at the alternator and start tracing wires.
battery full charge yet truck will not turn over?? NFCTWC General Tech 12 12-11-2012 08:51 PM
battery full charge yet truck will not turn over?? NFCTWC General Tech 3 12-08-2012 01:15 AM
Craigslist / eBay Find: 1998 5.0 (out of Mountaineer) (PA) brinker88 Engine & Drivetrain Parts 2 07-04-2011 11:48 AM
Craigslist / eBay Find: 1998 5.0 (out of Mountaineer) brinker88 Engine & Drivetrain Parts 0 07-03-2011 03:48 PM
Thoughts on a mountaineer...? pooleo General Ford Ranger Discussion 2 01-12-2011 07:12 PM
