Old 01-27-2013, 07:26 PM
ryan2c ryan2c is offline
Default Anyone using a reese universal hitch?
Anyone have any experience with a reese universal hitch? I found a good deal and was wandering if there are any pros or cons compared to the direct fit reese hitch. I have a 97 b4000 and will be using to tow a 5x8 trailer mostly hauling firewood. I can get the hitch for 75-80 bucks, only a couple months old. Thanks
97 b4000 se 4x4
Old 01-28-2013, 12:04 AM
AmericanPride! AmericanPride! is online now
The only con should be drilling holes, maybe custom brackets.
Pro...CHEAP
Old 01-28-2013, 12:39 PM
New pilot New pilot is offline
I installed the Reese universal trailer hitch on a 1996 Ford Ranger that I use to own. It was cheaper and I got a good deal on it but it was a pain to install. It comes in multiple pieces and seems kind of wonky to me. On my 2006 Ford Ranger I have the direct fit bolt on type and it was super easy to install. Both set-ups did not require drilling but on the Universal hitch you had to tie into the bumper bolts. Which was a pain.
Old 01-28-2013, 02:14 PM
cvar cvar is offline
Default Re: Anyone using a reese universal hitch?
Why would you want to? Ebay has the proper fitting Class III hitches for Rangers at about $100. No frame drilling needed. Fyi, it bolts to the bottom lip of the frame, 3 bolts per side (2 of those overlap with the bumper bracket bolts, whereas the 3rd bolt needs a 2"x4"x1/4" metal spacer). You'll still need a ball, pin, electric light plug, and mounting h/w, so maybe find one that includes all that. A Ranger hitch will fit your B4000.
1997 4x4 Mazda B4000 SE, Ext.Cab
Old 01-28-2013, 05:04 PM
I have everything else from my previous truck just need the hitch. Thanks for the info I think im going to pass on the universal and get the direct fit. I wasnt aware i can get one that cheap
97 b4000 se 4x4
Reese Hitch Mod GoGoPowerRanger Exterior Tech 9 07-10-2012 04:22 PM
Reese Hitch Installation Help Slater General Tech 11 03-18-2011 12:14 PM
For Sale: reese style hitch terryduanemiller Exterior Parts 1 02-13-2011 10:52 AM
reese hitch for a lifted truck? fenderix Exterior Tech 6 03-02-2010 03:11 AM
Want to Buy: Reese Hitch Falco51 Exterior Parts 6 01-25-2010 10:10 PM
