Old 01-24-2013, 05:33 AM
tyrrellrunnells tyrrellrunnells is offline
Ford Motor Co
Default lucas oil stabilizer
does any body run the oil stabilizer from lucas. just want to know if its worth it or not. and if it is safe on the motor.
Storm Trooper
Anzo Headlight assembely
K&N Cold Air intake
Old 01-24-2013, 08:14 AM
mooseranger mooseranger is offline
Default Re: lucas oil stabilizer
didnt think oil had to be stabilized. I have used the fuel treatment and didnt really see any result. Seafoam is good though. Search the trifecta. Is there a particular problem you are trying to solve adding this?
96 Ranger XLT 2.3L 2wd:
camo headliner, throttle cable mod, ignition coil mod, removed sway bar, 3" body lift, dual exhaust, 31x10.5r15 BFG
Old 01-24-2013, 08:43 AM
Backcountry96 Backcountry96 is offline
<<< 2000 Silverado
I put it in my Chevy silverado and it made my lifters knock but it is also an oil thickener and i put it in in like 0 degree weather so i would recommend it durring the summer or warm weather
Ford ranger 1996 5 Speed Sold
Chevy Silverado 2000
Old 01-24-2013, 08:47 AM
dvrich dvrich is offline
Ford and every US manufacturer warns against using additives of any kind.
2014 Ford F150 4x4 Supercab 5.0 STX 9500 miles 18 mpg overall....New Hampshire truck.
2015 Ford F150 4x2 Supercab 3.5 TIVCT 13,500 miles 21 mpg overall......Florida truck.
Old 01-24-2013, 09:18 AM
i'd stick with full synthetic oil, a good filter and no addatives. after seeing how well mobil1 full synthetic holds up after 5-6k miles it's all i use.
Old 01-24-2013, 01:53 PM
Psychopete Psychopete is offline
Psycho Pete
^^ there's no reason to run it. I have a 2.3L OHV approaching 200K that's only seen dino or syn-blend (whatever is on sale w/o a Fram or STP filter), 10w30 is all it needs, runs with no ticks, not even on cold first start up on these 10 degree mornings. Like Backcountry96 stated, you don't want to thicken your oil in cold climate.
4 Quarts 10w-30 & Oil Stabilizer zman7125 4.0 SOHC / 4.0 OHV Tech 10 04-04-2012 07:38 AM
Lucus oil stabilizer RockaRollaTruck 3.0 Vulcan Tech 1 11-02-2011 11:43 AM
Adding Lucas Oil Transmission Fix? canadianlonghorn79 Drivetrain Tech 2 09-20-2011 05:19 PM
Front Axle Seal Leak Stop...Lucas Oil??? jayty22 Drivetrain Tech 0 05-20-2011 06:43 AM
Lucas Oil Stabilizer. Bear General Ford Ranger Discussion 9 08-25-2009 09:15 PM
