Old 01-20-2013, 11:06 PM
TRWXXA TRWXXA is offline
Premature Curmudgeon
Default Re: Waterless coolant
Originally Posted by spring794 View Post
You do bring up some good points. It's a good idea in theory but you never know what will go wrong with the cooling system ex: leaks. Hopefully it will come down in price and become more popular.
The whole idea of it being waterless is to prevent leaks. The waterless coolant doesn't promote corrosion which is what causes most coolant system leaks and failures. The rest are typically hose failures due to poor preventive maintenance. Whose fault is that?
2011 Ranger XLT 2WD - Dark Shadow Gray Metallic -- SOLD
- Richmond Gear, POWERTRAX No-Slip differential -- FOR SALE
- Advantage, Torza Hard Hat tonneau cover -- FOR SALE
2016 Ford Explorer - Shadow Black
2010 MINI Cooper - "Der Krautenküper"
1993 Special Service Package Mustang - The Five-O's 5-0.
Old 01-21-2013, 02:16 AM
My question is: why?
Regular extended life coolant works excellent.
Old 01-21-2013, 11:14 AM
But it is still water based, and will eventually corrode your cooling system components unless it is replaced regularly. The waterless coolant will last the life of the vehicle.
Old 01-21-2013, 05:41 PM
Your engine will fail if you don't replace the oil regularly. Coolant is a maintenance item, just like engine oil. It does need to be replaced
Old 01-21-2013, 05:43 PM
Yes coolant is just like any other fluid....needs to be changed regularly....
Sent from my HTC One X using FRF App so you can hate on my F150 no matter where I am
18 F150 Supercab XLT 2.7
Old 01-21-2013, 09:16 PM
Was I typing in a foreign f***ing language?!
The waterless coolant system does not have to changed regularly, unless you contaminate by adding water.
Evans Waterless Coolant
Regular coolant must be changed at regular intervals because the chemical additives in the water lose their anticorrosion properties over time, and will destroy your cooling system and engine from the inside, out. Evidence of this shows up as the brown sludge you drain out of your radiator. That is rust that used to be part of your motor.
The idea of the waterless system is that the coolant contains no water, so it doesn't corrode and doesn't boil. So the cooling system is not being weakened and clogged up by corrosion and high operating pressures.
Now, converting to the waterless stuff is supposed to cost about 3 or 4 times what a regular coolant change costs. So unless you plan on keeping the vehicle for at least 6 to 8 years, you might not feel that the extra cost is worth it.
Old 01-22-2013, 04:31 AM
Idc what the coolant is made of it still needs to be changed at regular intervals
Old 01-22-2013, 08:02 AM
RoberticusMaximus RoberticusMaximus is offline
hmmmmm... what about moisture condensing inside the overflow??? that would quickly contaminate the overflow tank, right???
Old 01-22-2013, 09:48 AM
spring794 spring794 is offline
Ukrainian Automotive
Wouldn't the moisture condensing in the overflow be from the water in conventional coolant? I don't think you'll have that problem with the waterless stuff.
I am actually considering to change to the waterless coolant after my next oil change (I also plan to switch to synthetic oil).
Sent from my iPhone using FRF App
1995 Mazda B2300 SE
Old 01-22-2013, 09:49 AM
No it would be the temperature difference between the engine coolant and the outside air causing condensation
Old 01-22-2013, 09:53 AM
Well that is something to look into. Although if the overflow tank is sealed well and clean, I don't think the moisture would cause contamination. Although I maybe wrong.
1995 Mazda B2300 SE
Old 01-22-2013, 10:55 AM
you's in houston tx lol! home of the worst humidity problem on earth lol! if it were a problem at all, it would be down there lol!
anyway, the tank has to breath when the radiator purges into it & sucks fluid back in after it cools...
Old 01-22-2013, 11:42 AM
ricochet ricochet is offline
I took a quick look at the waterless coolant website and I didn't see anything related to compatibility with head-gaskets. Not worth the risk IMHO. I'll just change the Ford Premium Gold coolant in my 2011 sometime before the 168,000k/6yrs that Ford specifies - most likely 4yrs/120,000km...
Here's a good read on the latest coolants: http://www.gates.com/downloads/downl...older=brochure
2011 Supercab Sport 4x4, 4.0L, Auto, 3.73LS.
Old 01-22-2013, 02:16 PM
Yea you gotta love Houston's weather.
1995 Mazda B2300 SE
Tags
coolant
Coolant temp Sensor or Coolant Sender - Can you name that part? JSobo 3.0 Vulcan Tech 2 09-16-2012 06:07 PM
coolant monkey2020 4-Cylinder Tech 4 08-23-2012 09:10 PM
Oil in coolant, coolant in oil. Doing head gasket job on 1995 3.0 Tommy2 3.0 Vulcan Tech 17 11-22-2011 03:52 PM
No Coolant Cdy291 3.0 Vulcan Tech 7 05-22-2011 05:21 PM
Radiator Level Low, Coolant Still in Reservoir Still Has Coolant DHowesGrnXLT4x4 4.0 SOHC / 4.0 OHV Tech 4 03-25-2011 09:23 AM
