  #61
Old 03-13-2011, 08:54 PM
VegasRanger02 VegasRanger02 is offline
Default Re: Gas! Does it matter?
Ya, gas matters. There are standards that exist I am sure, but some gas is "cleaner" and just "more better" lol. They use high quality processing etc etc to produce a better more expensive product. I try to use the best gas I can afford lol. Chevron is one of the best, but its the most expensive in Vegas. Shell is expensive too.
And some one made a point about ethanol needing more volume to produce the same effect as gasoline in smaller amounts. Some one also said something about it being more oxygenated. This is alll true. Go to california, and it is about all you can find is "ethanol enriched" gasoline, which burns way faster (less mpg) and is usally pricey anyways. They use it because it burns cleaner and Cali is a green freak - which is a good thing. IMO
2002 Ranger XLT 3.0
General Grabber AT2 31/10.5/15, 15x7 ATX Slot, Hot girlfriend for passenger seat, Fabtech 2.5", Bilstein 5100, Poly Bumps, JBA Ceramic Coated Headers, Straigh pipe, Throttle Cable Mod, Air Box Mod, 5 Angle Valve Job, 180* Thermostat, Clear corners w/ Amber LEDs, Tinted Tails, 6000K Volt Digital HID Hi/Lo, K&N Drop-In, MAF Mod,
Old 03-14-2011, 08:19 AM
Originally Posted by tcmills3 View Post
i get .5 to 1 mpg better without using e10. i go with regualr
Lucky bastard! All we have is E10 and E85 around here. In the winter, we get the "bonus" winter blend that gives even crappier fuel mileage.
1999 Honda CR-V EX, RT4WD, 2.0L, 5 Speed MT, 4.56:1, open differential
