  #14161
Old 06-25-2010, 10:09 PM
lol than u drive it like me check them out if it is them they will soon melt ur seal and u will be leaking diff fluid everywhere like i did cuz i couldn't narrow it down till it started leaking and it threw a chuck of my pinion tooth too i was pissed i guess if something get drivin long enough and gets really hot bad things happen i'm just glad the bearing didn't blow up and have chunks of metal in there destroying everything u might want to changed ur diff fluid and check them out man
  #14162
Old 06-25-2010, 10:24 PM
How do I check them out? open up my dif? if thats the case...maybe I can talk my buddy into just giving me his from his mustang early...will have 4 lug in the back, but 4wheel disc brakes.
  #14163
Old 06-25-2010, 10:29 PM
lol well if ur wanting a new axle i guess now is the time lol and yea open it up and check everything in there u might be low on fluid u never know
  #14164
Old 06-25-2010, 10:34 PM
I dont even know how to check/replace the dif. Those and transmissions have always sketched me out. tried to take a FWD auto trans apart once and when I opened it up, little ball bearings fell out and it looked like a maze...that was the end of that trans.
  #14165
Old 06-25-2010, 10:51 PM
lol first don't do this without diff oil and a gasket or that rvt black or grey sealent hahaha second unbolt all the bolts on ur diff cover third let it drain slow don't pull the cover of or it will go everywhere 4th look at everything in there with a fine pick and comb to make sure there is no dis coloration like if it got to hot and see if anything is chipped or teeth missing but the real tell tale sign ur bearing are bad is there will be little metal shaving at the bottom of ur diff if there is bam u found it if not well it prob needed a diff oil change anyways lol
  #14166
Old 06-25-2010, 10:52 PM
Lol
Old 06-25-2010, 11:00 PM
Lol
twin turbo or one?
  #14168
Old 06-25-2010, 11:01 PM
twin turbo or one?
quad turbo
  #14169
Old 06-25-2010, 11:14 PM
lol damn that thing is huge
  #14170
Old 06-25-2010, 11:18 PM
thats what she said
  #14171
Old 06-25-2010, 11:23 PM
thats what powers them bugatti veyrons
  #14172
Old 06-25-2010, 11:28 PM
to bad it wouldn't fit in a ranger lol
  #14173
Old 06-25-2010, 11:30 PM
you could make it fit...just extend the piping and run some under the truck up into the bed...like those STS turbo kits. (i think they are the sts turbos that are in the back.)
  #14174
Old 06-25-2010, 11:32 PM
that would be a sick ranger with that in it
  #14175
Old 06-25-2010, 11:35 PM
yep, rear engined ranger!
