Old 10-18-2012, 01:16 PM
03 SB FX4 03 SB FX4 is offline
Official FRF Redneck.
Send a message via Yahoo to 03 SB FX4
Default Computer gurus I could use some help???
Hey guys,
I have a laptop with windows 7 and I have hooked it to my HDTV and it works fine.
So.......... What I am wondering is how do you get it to work dual screen so you have 2 things open at the same time?
Any help is appreciated!!!!
(Project Dirty Girl) 06 Chevy 3500 CCLB DRW 4WD (D-Code) LBZ Duramax - Air Box Mod, High Flow Filter, Turbo Silencer Removed and capped, LMM Sensor Pack, LML Turbocharger Solenoid, EFI Live Tuned by Myself, TranSynd for the Allison, Awaiting more mods, 100 + Injectors, PPE Hot Fueler Kit, PPE Dual Fueler kit, PPE Compound Kit and Mike's ALLY Trans Setup - Inglewood Trans!
Old 10-18-2012, 01:32 PM
Default Re: Computer gurus I could use some help???
Hey guys,
It should be controlled by the Display > Settings in the control panel. However if the video card or that portion of the motherboard is not set up for it you will not be able to use both the screen and TV.
If I am wrong though someone please correct me.
Old 10-18-2012, 02:37 PM
Joe - how do you find out if its set up for it?
Old 10-18-2012, 02:55 PM
reconjb reconjb is offline
Found a Diesel
control panel > apperance and personalization > connect to external Display > and there should be a drop down box that will alow you to select duplicate monitors, extend monitors, or single monitor you will want to extend them.
Truck: 2000 Ford Ranger XLT 4.0 4x4 ext cab
My Build Thread
Mod Ideas
Don't Forget to:
Create a Signature
Show your system
Mods: Brush guard|Front Hitch|Expo Roof Rack|Train Horn|Door/Dash/step/Hood Leds|2" lift|Rear Tow Points|On-Board Air System| 22" & 40" LED bar|and More!
Old 10-18-2012, 02:56 PM
Thanks Jake, I knew I was missing something
Old 10-18-2012, 02:59 PM
RoberticusMaximus RoberticusMaximus is offline
you guys are quick!
Old 10-19-2012, 05:10 AM
Thanks guys, I will try that when I get home!
Old 10-19-2012, 05:17 AM
sole sole is offline
Hold down control the windows button then the letter p it should pop up a menu for projector settings
Sent from my iPhone 4 using FRF App
Black 2008 ranger sport 4.0 SOHC SAS'd and converted to 4x4 riding on a Dana 50 up front and a sterling 10.50 in the rear regeared with 5.13's, mickey thompson classic 3's rapped in 37x12.50 maxxis creepy crawlers
Old 10-19-2012, 07:54 AM
you guys are quick!
That's what she said!
2019 Ford Ranger STX FX4, Super Crew, 2.3L Ecoboost, 10 speed automatic, 3.73:1 with rear locker, Leer 100XR cap
Old 10-19-2012, 07:59 AM
i should've seen that coming lol!
Old 10-19-2012, 08:11 AM
tacho19871987 tacho19871987 is offline
buahahaha!!!
Old 10-19-2012, 11:14 AM
Thanks guys. Got it working now just waitin' on shizzle (Sean) to get off work and come hook up my new router!
Ford 2.3 engine gurus. Help. Lincoln Log 4-Cylinder Tech 4 05-27-2012 11:28 PM
Need help from you pedal bike gurus'! pooleo Off Topic 42 03-06-2012 01:51 PM
questions for the CB gurus pooleo Audio / Video 9 11-06-2011 07:51 PM
sub gurus help needed! cleanest 8's??? darangerdanger Audio / Video 8 10-10-2010 03:12 PM
suspension gurus... need an opinion FX4 Suspension Tech 1 07-06-2010 02:37 PM
