11-07-2011, 08:13 PM
Ford Five Hundred Problems
So my moms car has a few things wrong with it that she wants me to fix for her because shes put a lot of money into it already and doesn't want to take it in anywhere. So here's a few of the problems I'm hoping you guys could help me out with. First thing is her backup sensors (rss) don't work. The switch on the dash just stays lit up on OFF. If you press it nothing happens. Also her heated seats arent working . Same thing with those switches. I looked in the manual and they were both in there as the same fuse so I checked that fuse and it was still good so I'm kinda out of ideas. Im so lost when it comes to electrical on cars. So any help is appreciated, Thanks guys
2002Ford Ranger
- V6, 4.0, Auto,4x4, Stepside, Ext cab, Wedgewood blue
11-07-2011, 08:26 PM
Wow.So cobra.Very Ranger.
Re: Ford Five Hundred Problems
even though the fuse looks good, pull it and replace it, and see what happens
I had a fuse go bad in my ranger, but it still looked alright. I put a new one in, and bam, problem solved
Chrome Yellow 2001 Ranger Edge 3.0L V6/5spd
11-07-2011, 08:36 PM
ditto on what he said
11-08-2011, 12:16 AM
Semper Paratus
If the fuse doesn't fix the problem, check the line voltage. I had a car once do the same thing. The electric seats, hvac controls, 4X4 switch, etc. wouldn't work. Ended up being a bad ignition switch. Voltage was only about 3.5 from the switch. Replaced it and everthing started working again.
'20 Ranger Lariat FX4 Oxford White
11-25-2011, 11:02 PM
Just replaced the fuses today ad have the same problem ill look into the ignition switch but the only things not working are the seats ad reverse sensors. The hvac etc is all good
2002Ford Ranger
11-27-2011, 01:52 PM
Is there power at the fuse?
