Old 07-27-2011, 10:51 AM
SalRanger2 SalRanger2 is offline
LOWERED!
Default ATV help needed
we have a '86 Yamaha Moto 4 yfm200 four stroke.
looks like this
anyways, it would run fine but it would have a loud tick, like a lifter or something. the other day it was idling and just quit. now it acts as if it was seized up, wont turn over. tried pushing it then slamming it into gear and still wont turn over.
dont have alot of experience with atv's so wondering where to start. dont want to have to tear it apart.
thanks
'99 Ranger XLT Reg. Cab Stepside
2.5L
2WD
5spd
K&N Filter
Air Box Mod
Explorer OHC
2/3 Drop
Join!! FRF no-lifers Clan
Old 07-27-2011, 09:47 PM
aulee42 aulee42 is offline
In the ice shanty
Default Re: ATV help needed
your valves need(ed) adjustment, and or your rockers are shot
2004 XLT 4x4, Belltech 6400 shackles,Chevy leaf springs, Mildly cranked Tbars,stock blocks removed,265/75/16, Construction cap,
Old 07-31-2011, 03:37 PM
LOWERED!
ok thanks alot, well i guess we'll be tearing it apart then
2.5L
2WD
5spd
K&N Filter
Air Box Mod
Explorer OHC
2/3 Drop
Old 07-31-2011, 03:47 PM
meh, prolly something in the crank. Or, has it been exposed to ANY type of water? Is it at all possible it got water in the cylinder..??? even if you took out the rocker assembly so the valves were shut, the motor would still turn over. You either got a mechanical problem, the crank is seized or is hydrolocked.
Old 07-31-2011, 03:49 PM
LOWERED!
yea i dont think hydrolock could have happened never had it in/under water and it had good oil in it too. yea maybe that was the rod knocking who knows. probly just take the head off and see if its something in the top end
2.5L
2WD
5spd
K&N Filter
Air Box Mod
Explorer OHC
2/3 Drop
Old 08-01-2011, 06:59 AM
Could have dropped a valve and now it's stuck between the head and piston
Old 08-01-2011, 08:05 AM
LOWERED!
thats another thing i was wondering about...
i dont see alot of these atv's so i hope its not too hard/expensive to get parts
2.5L
2WD
5spd
K&N Filter
Air Box Mod
Explorer OHC
2/3 Drop
Old 08-01-2011, 11:18 AM
awk08 awk08 is offline
BLASTED SINCE 1996
i'd start by looking at the timing chain, a worn chain would make the "tick" you described, a severly stretched chain coulda had the timing out so far you bent a valve ???
then i'd look into the starter mechanisms, electric and pull,
one of them may have seized/jammed, then into the clutch cover to look for culprits,
all the above will require pulling timing gear cover on the head, and flywheel and clutch covers, if your careful not to tear the gaskets ...it won't cost ya anything
and lastly pulling the head to check for valvetrain carnage as mentioned above
just rebuilt an older 97 kawi lakota 300, and i too had problems finding used parts, finally found a good used head on ebay (the old cam and rockers were wiped out)
but bikebandit.com will have new parts, i just ordered an oil pump cover for the lakota, and found new piston/rings/timing chain on ebay
i've also stripped and rebuilt/modded 5 blasters, and just did the top end on my buddies ktm144 gncc/mx race bike, for the second time
my builder in connecticut .......
KENOCONNORRACING.COM is the best i have found for price and quality around, well worth the money for shipping my stuff to him, i've had a local yamaha dealer, and auto machine shop both fugged my shit up before!!!!!!
i'll try to keep an eye out on this thread, or PM me if ya need any other help
we also have some very knowledgable tech's over on blasterforum.com, that'll be more than willing to help you even though it's not a blaster, it's still a yami !!!!!! and i've seen a few moto4's on there before
head on over and sign up if ya want, and tell 'em awk sent ya
ps......pics of carnage are a must !!!!!!!!
'02 Ranger Supercab, 4.0l, 4x4
Magnaflow catback duals, SB cold air intake
16" Bridgestone Blizzaks, Bilstein HD's
http://kenoconnorracing.com/ for all your 2 & 4 stroke engine atv/bike/sled/jetski needs !!!!
http://www.blasterforum.com/members/awk08-5502/
Old 08-01-2011, 01:38 PM
BLASTED SINCE 1996
a quick check of ebay shows some used parts available.............
http://cgi.ebay.com/ebaymotors/Yamah...Q5fAccessories
Old 08-01-2011, 02:26 PM
LOWERED!
wow thank you very much! i will definatly have to look into the timing chain as well. yea i will have to take some pics if its crazy messed up inside. ill will probly check out that forum too, the more ya know the better. Thanks a ton man
2.5L
2WD
5spd
K&N Filter
Air Box Mod
Explorer OHC
2/3 Drop
Mx Vs. Atv Alive IrideAHonda Music/Movies/Computers/etc. 2 05-10-2011 05:29 PM
Dont get stuck with plow on atv aulee42 Off Topic 11 03-04-2011 03:07 PM
Street Legal ATV? joshawol Off Topic 10 02-28-2011 07:00 PM
drag atv LT450R Vehicle Snapshots 26 11-18-2010 06:13 PM
atv batterys greyghost Off Topic 42 12-27-2009 09:55 PM
