Old 12-20-2012, 10:10 PM
mcesar84 mcesar84 is offline
Default Re: Mobil 1 vs Castrol Edge
Mobil 1 for me. $27.xx for the 15k advanced synthetic at walmart. Also picked up a Bosch Distance Plus filter for $12. $40 for a year of good engine health, can't beat that.
Mike
'08 Sport 4.0 4x2 5AT
'06 Acura TL 6MT
'96 XL 3.0 4x2 4AT (Sold 9/3/12)
Old 12-21-2012, 11:06 AM
dvrich dvrich is offline
Originally Posted by brett20 View Post
i used the castrol last oil change, this oil change im using mobil 1 so we'll see which one is best
How exactly will you know which one is best unless you have an oil analysis done.
If you don't do extended oil change intervals, all synthetic oils protect the same.
2014 Ford F150 4x4 Supercab 5.0 STX 9500 miles 18 mpg overall....New Hampshire truck.
2015 Ford F150 4x2 Supercab 3.5 TIVCT 13,500 miles 21 mpg overall......Florida truck.
Old 12-21-2012, 12:58 PM
Jackarino Jackarino is offline
Mobil One
2005 Ford Explorer XLT 4.0
2003 Ranger Regular Cab 7FT Bed XLT 3.0 (SOLD)
Mods: Throttle Cable, Air Silencer Removal, 06+ Badges, Tails, and Corners
Old 12-21-2012, 01:18 PM
Dwood63 Dwood63 is offline
Rotella T
96 4.0L 4x4 automatic regular cab leveling kit 31x10.5x15
Old 12-21-2012, 03:47 PM
Originally Posted by Dwood63 View Post
Rotella T
5w-40? Just how worn out is your engine?
Old 12-21-2012, 04:11 PM
Rotella T
Using diesel oil in a gas engine is not the best idea... It's not just that its a 15w40 or a 5w40, it's the properties of the oil as well.
Old 12-21-2012, 04:51 PM
I was just throwing out a type of oil, and the only difference is that it has more additives for cleaning the engine
Old 12-22-2012, 09:20 AM
BuckB BuckB is offline
Rotella T
Rotella is used by a lot of truckers. Not sure about Rotella T if it's a synthetic or not. Years ago Caterpillar was one of the first to use turbo charged engines. They ran into a problem with oil getting so hot in the turbo's bearing that sits between the exhaust and intake side it would actually carbon up and shut the flow of oil off. They then developed a new oil spec to use with the Cat turbo charged engines. They called it Series 3. Rotella meets that spec. We were replacing Turbo's with way too low hours.
Old 12-22-2012, 10:00 AM
It wont actually hurt it. The diesel oils like series 3 in my post above do hold impurities in suspension. The result is less sluge/carbon build up.
Old 12-22-2012, 10:02 AM
All it is is a diesel oil that has extra additives in it to clean, for an example cat switched to it because it cleans up carbon build up
Craigslist / eBay Find: 04 Edge darksyde Trucks 1 06-08-2011 07:51 PM
Castrol vs pennzoil brett20 3.0 Vulcan Tech 7 03-15-2011 10:18 PM
Castrol GTX Cdy291 3.0 Vulcan Tech 5 03-07-2011 12:48 PM
took the Edge to the edge azgilamonster Vehicle Snapshots 8 09-14-2010 02:25 PM
My 05 Edge CJG Vehicle Snapshots 18 06-26-2009 01:19 PM
