Old 05-18-2011, 03:46 PM
Default Help with CHEVY Brakes! ASAP!!!
For you chevy guys out there, what the hell is the deal with these brakes!!! 96 GMC Yukon 2wd 5.7. Pass side rear wheel cyl. shot. Replaced both wheel cyl. new brake lines and new shoes. Put it all together and NOTHING comes out the bleeders, not even AIR!!! Pedal is good a firm and does not change when rear bleeders are open. I search online and found that (I think) this truck has an electronic proportioning valve. Is this the problem..? Way to reset it..?
Thanks in advance!
Old 05-18-2011, 03:49 PM
ben10 ben10 is offline
slut life
Default Re: Help with CHEVY Brakes! ASAP!!!
does it have a proportioning valve on the frame like a toyota?
99 extended cab, 4.0, auto, 33s, 4x4 lifted with some stuff done
98 2wd 2.5, 5 speed, dropped with some stuff done
Old 05-18-2011, 03:50 PM
I'll look...
Old 05-18-2011, 04:00 PM
If it is an "electronic" proportioning system...you could possibly reset it by unhooking the battery for a few minutes.
Originally Posted by 05RangerEdge View Post
Nobody won here today but I am pretty sure you just lost.
Old 05-18-2011, 05:04 PM
^^^yeah, I had it un hooked for dinner, seemed to work. damn chevys!!!
hyrdro brakes to air brakes? Rubber Duck General Ford Ranger Discussion 8 02-03-2011 10:51 PM
Need help ASAP!!!!! 98rangerxlt Drivetrain Tech 2 06-09-2010 10:05 PM
Need help asap!! Milla709 3.0 Vulcan Tech 7 06-04-2010 10:04 PM
Need help asap! Ranger01 Interior Tech 3 12-24-2009 03:20 PM
Need Help ASAP.. sdfishman 4.0 SOHC / 4.0 OHV Tech 7 06-26-2009 08:00 PM
