Old 01-31-2011, 07:28 PM
aaron_ariens aaron_ariens is offline
NO H8.
Send a message via AIM to aaron_ariens Send a message via MSN to aaron_ariens
Default 1995 Acura Integra help?
Alright, so my friends 95' Integra LS 4-cyl non vtech, automatic, is having some starting issues, was wondering if you guys had any idea as to what the problem is. (This is basically my weekend car aswell)
When you start the car when its cold, all is good. No issues at all.
When you start the car after its warmed up, it starts normal, then just dies. Like the RPMs go up, then come straight down. To start it after its warmed up, you have to start it, then rev it up to about 5k, then let off the gas and it'll stay on.
*New fuel filter, new engine ~130k, runs perfect, no engine light.
Any idea's guys?
I know the #1 issue is the "Honda motor co" on the engine, but besides that. Hahahaha.
2001 Ford Ranger XLT 3.0 V6 Automatic.
1995 Acura Integra LS
PNW Crew!
http://www.facebook.com/aaron.ariens
Lol, Aaron: "I only text with trees, it makes it hard to text while driving though, I have to keep running the truck into trees to text!!" EPIC my friend. Lol
Old 01-31-2011, 07:33 PM
Default Re: 1995 Acura Integra help?
any check engine lights? does hot cranking seem/ sound/ feel normal?
Old 01-31-2011, 07:34 PM
NO H8.
Noe engine light, and everything is PERFRCT...it just dies, like kicks to like 1500/2000k, then off.
PNW Crew!
Old 01-31-2011, 07:39 PM
DangerRanger2000 DangerRanger2000 is offline
Twist It Back!
Sounds like a distributor problem, will it crank back up with you reving it right after it shuts off?
2000 XLT 4x4 EXT. CAB 4.0/Auto Trans/3.73 gears/
31x10.50 BFG Rugged Terrains on MB Motoring Wheels/Pioneer Head Unit/JBL 12"/Camo Interior/'03 black and grey 60/40 seats/ green LED's Under Dash/T-Bar Crank/Windows-20% on the front, 5% on the back/Mustang Dome Light/06 Tails/
Old 01-31-2011, 07:40 PM
NO H8.
Hmm, I'm not sure! I'm like glad it starts so I just speed off haha.
PNW Crew!
Old 01-31-2011, 07:43 PM
Twist It Back!
Ohh well then its probably not the distributor, if it was it wouldnt crank up after it shut off until the distributor cools back down. Have you tried a new fuel pump? Its probably reving up right before it shuts off because it is trying to suck gas but it isnt getting any.
Old 01-31-2011, 07:44 PM
NO H8.
But when its cold it starts fine? Would that still make sense with the fuelpump?
PNW Crew!
Old 01-31-2011, 07:47 PM
Twist It Back!
Hmmm didnt think about that. Does it run fine until you shut it off and then try to crank it again?
Old 01-31-2011, 07:49 PM
NO H8.
Yeah! Thats why this is so tricky!
PNW Crew!
Old 01-31-2011, 07:54 PM
Id check the coil, when hot the coil heat soaks and might not start then. Is there spark when this happens?
Old 01-31-2011, 07:55 PM
Twist It Back!
Idk man sounds like something is getting hot and shutting it off when it does. I would think that if it was the distributor it wouldnt crank back up at all until it cooled off. And it really sounds like a fuel pump problem but it cranking fine when it is cold is confusing. Your right on the tricky part lol.
NO H8.
I'm not sure, I'll have to look into it further.
I won't have the car with me till Friday
PNW Crew!
Old 01-31-2011, 08:34 PM
terryduanemiller terryduanemiller is offline
www.shanewootenband.com
bad TPS will cause a Honda to do crazy things
MY BUILD THREAD
1999 MAZDA 2500SE, 2.5L 4-clanger, 5 speed, Green n slow. Rangers as daily drivers since 1988.
ASE Certified Mechanic, Builder of Show Destroying Protouring and Classic cars..
Old 01-31-2011, 09:01 PM
NO H8.
Hmmm
PNW Crew!
Old 01-31-2011, 09:27 PM
here is where you went wrong "honda"
1995 radiator support MOOSEMAN2906 Exterior Tech 3 06-29-2016 04:15 PM
1995 turn signals TexasRanger16 Electrical Tech 1 11-14-2010 10:26 PM
For Sale: 1995 Ranger NJMedic Trucks 2 08-13-2010 05:14 AM
Not Ford but need help on HID bulbs on Acura...? DrIftKi7Vg Electrical Tech 13 06-19-2010 12:58 AM
1995 won't start dpertell 4-Cylinder Tech 0 08-30-2009 09:18 PM
