Old 01-22-2011, 01:45 PM
brokenIN brokenIN is offline
Default 95 cadillac eldorado question
My coworker drives an eldorado and it will only start in neutral. whats the problem!
Old 01-22-2011, 01:53 PM
Default Re: 95 cadillac eldorado question
Neutral Safety Switch
Old 01-22-2011, 02:03 PM
Will it damage the vehicle to start it in neutral until its fixed?
Old 01-22-2011, 02:07 PM
rangersplash rangersplash is offline
No. The switch only prevents you from starting the car with a gear so that it will move uncontrolled....
Stefan
1996 Ford Ranger SPLASH 4.0 2WD 5 speed manual
real man dont need a front wheel powertrain...
Old 01-22-2011, 02:10 PM
Thanks gents! She's thankful for the help
Old 01-22-2011, 02:15 PM
No
Stefan
No, the switch can fail in certain positions as well, otherwise, it could also be that the shift linkage (the link between the shifter in the vehicle and the transmission) is worn out and will not properly engage the vehicle in park, it could be worn in the column, assuming this is a column mounted shifter, or at the transmission. They can be adjusted but I would just go ahead and replace it if he can afford that or do it himself.
not your daddy's cadillac... IndianScout Vehicle Videos 8 12-04-2010 09:00 PM
around here we roll cadillac golf carts (GM content) FoMoCo Vehicle Snapshots 7 05-03-2010 03:37 AM
