02-09-2014, 02:15 PM
Tools? Let me see....
DRILL PRESS: A tall upright machine useful for suddenly snatching flat metal bar stock out of your hands so that it smacks you in the chest and flings your beer across the room, denting the freshly-painted project which you had carefully set in the corner where nothing could get to it.
WIRE WHEEL: Cleans paint off bolts and then throws them somewhere under the workbench with the speed of light. Also removes fingerprints and hard-earned calluses from fingers in about the time it takes you to say, 'Oh sh --'
SKILL SAW: A portable cutting tool used to make studs too short.
PLIERS: Used to round off bolt heads. Sometimes used in the creation of blood-blisters.
BELT SANDER: An electric sanding tool commonly used to convert minor touch-up jobs into major refinishing jobs.
HACKSAW: One of a family of cutting tools built on the Ouija board principle... It transforms human energy into a crooked, unpredictable motion, and the more you attempt to influence its course, the more dismal your future becomes.
VISE-GRIPS: Generally used after pliers to completely round off bolt heads. If nothing else is available, they can also be used to transfer intense welding heat to the palm of your hand.
OXYACETYLENE TORCH: Used almost entirely for lighting on fire various flammable objects in your shop. Also handy for igniting the grease inside the wheel hub out of which you want to remove a bearing race.
TABLE SAW: A large stationary power tool commonly used to launch wood projectiles for testing wall integrity.
HYDRAULIC FLOOR JACK: Used for lowering an automobile to the ground after
you have installed your new brake shoes, trapping the jack handle firmly under the bumper.
BAND SAW: A large stationary power saw primarily used by most shops to cut good aluminum sheet into smaller pieces that more easily fit into the trash can after you cut on the inside of the line instead of the outside edge.
TWO-TON ENGINE HOIST: A tool for testing the maximum tensile strength of everything you forgot to disconnect.
PHILLIPS SCREWDRIVER: Normally used to stab the vacuum seals under lids or for opening old-style paper-and-tin oil cans and splashing oil on your shirt; but can also be used, as the name implies, to strip out Phillips screw heads.
STRAIGHT SCREWDRIVER: A tool for opening paint cans. Sometimes used to convert common slotted screws into non-removable screws and butchering your palms.
PRY BAR: A tool used to crumple the metal surrounding that clip or bracket you needed to remove in order to replace a 50 cent part.
HOSE CUTTER: A tool used to make hoses too short.
HAMMER: Originally employed as a weapon of war, the hammer nowadays is used as a kind of divining rod to locate the most expensive parts adjacent the object we are trying to hit.
UTILITY KNIFE: Used to open and slice through the contents of cardboard cartons delivered to your front door; works particularly well on contents such as seats, vinyl records, liquids in plastic bottles, collector magazines, refund checks, and rubber or plastic parts. Especially useful for slicing work clothes, but only while in use.
Son of a bitch TOOL: Any handy tool that you grab and throw across the garage while yelling 'Son of a bitch' at the top of your lungs. It is also, most often, the next tool that you will need.
Drive fast, take chances...
02-09-2014, 02:19 PM
Lmao
02-09-2014, 02:24 PM
Re: Tools? Let me see....
Glad you liked you it. It's funny how real some of these become.
02-09-2014, 02:28 PM
Yea I'm most familiar with the son of a bitch tool lol
02-09-2014, 02:32 PM
My pliers have become my son of a bitch tool after one of those blood blisters a few times lol
02-09-2014, 02:39 PM
Useless olde guy
Buzz Box, a tool used to join two pieces of metal, and burn holes in your pant legs and sox. Also handy to blister feet once the hot sparks locate the top of your boots.
'04 Edge, Scab/flareside, 2wd, 3.0, 5 speed, 4:10 open. Billet grille, Raceline Raptor black wheels, 265/75/16 DuraTracs. Tbar crank, AAL. Fox shocks, Thrush welded SI/DO swept back side exit. Morimoto projectors, '06 tails and power mirrors. LEDs all the way around. Blacked out fender badge. Access Limited rollup tonneau. 5% tint on back three windows. Airbox mod, FWIW. And a Border Collie that likes it too!!
02-09-2014, 03:40 PM
We must get our tools from the same distributor
Black '98 XLT 4.0 liter, super/extended cab, 4X4, 5 speed manual
*Mods & Pseudo Mods*
Sony head unit, Expo OHC, Uniden CB, 16" Wheels from a 2002 Expo Sport Trac/255-0R16 tires
02-09-2014, 05:01 PM
Another old fart
Me too. LMAO.
2000 Ranger Extd Cab XLT, 4X4 Off Road, 4.0L, Auto, 8.8 - 4.10's, 01 grille & lights swap.
69 Mustang, modified 5.0, & 5spd.(project)
99 Explorer Sport, 4.0 SOHC, Auto, 8.8 - 4.10's, PW, PL, PM, Cruise, Tilt. (Wife's DD)
05 F-150 2WD Regular Cab. ( My DD)
02-09-2014, 05:18 PM
1. Use a clamp
2. Use a clamp
3. Measure twice cut once
4. Use the correct tool
5. Use the correct tool
6. Come on....."hack" saw ...... use the correct tool
7. ONLY if the correct tool isn't available, use these first.........and use gloves
8. Use the correct tool.......or have a fire extinguisher handy
9. Use a push tool.....and anti feedback fingers provided with said tool
10. Use the correct tool, or blocks
11. Work smarter not harder
12. Work smarter not harder
13. Use the correct tool
14. Use the correct tool, wear gloves
15. Use the correct tool
16. Measure twice cut once
17. LEARN HOW TO USE THE CORRECT TOOL
18. LEARN HOW TO USE THE CORRECT TOOL
19. Follow my list and never reach for this imaginary tool
02-09-2014, 05:19 PM
Older Than Dirt !
You forgot one, the famous wire stripper-screw cutter-wire cutter.The screw cutter is a deadly weapon, works great on the small ones but a 10-32 screw is good for cutting a major chunk out of your finger with the wire cutter on the end,you squeeze so hard to cut the 10-32 screw that when it snaps look out!
(ask me how I know)
02-09-2014, 05:30 PM
I Know This Truck . . .
good stuff!
2007 Sport |Dark Shadow Grey |3.slow |2WD |Black Billet Grill |Anzo LED's
#FFR
Pictures
02-09-2014, 08:24 PM
+1
2001 Ford Ranger - Flareside - XLT - Off-Road - 4.0 - 4x4 - Automatic OHC - 06+ Corners - 06+ Tails - Soft Tonneau
02-10-2014, 11:49 PM
Forgot the classic BFH (big fu**ing hammer). Best tool for Fords lol.
Originally Posted by stateranger
02-15-2014, 01:34 AM
Mr H....A....P...P....Y👿
I used it to do the driver side bushing.
2014 F150 xl 3.7 6 speed auto.
Originally Posted by pk9298
HELL TO THE NO!! Abort abort abort!! That's the first thing to go!!! Ewwwww! I'm not no vampire! I don't enjoy red tea
