Old 01-11-2011, 08:25 AM
azgilamonster azgilamonster is offline
grumpy old ford driver
Default for those that weld might want to read this
http://www.brewracingframes.com/id75.htm
Do not use brake cleaner to clean grease off your metal before welding
2001 Ranger Edge 4x4 , Stepside,FRF decals, 4.0L SOHC decals, Primus IQ brake controller, curt 2" rec. hitch, custom winch mount,
Tinted glass, Yellow BUGGMAN OVALS a real treat to have. OHC, CB, night vision goggles, 36" periscope,
DiabloAmarillo = The Yellow Devil
Old 01-11-2011, 08:33 AM
Superlifted06FX4 Superlifted06FX4 is offline
Send a message via AIM to Superlifted06FX4 Send a message via MSN to Superlifted06FX4
Default Re: for those that weld might want to read this
I thought that was common sense... And I think this is a repost, but good info none the less.
Old 01-30-2011, 09:43 AM
Zipzag Zipzag is offline
Collision Repair.GM Tech
Guess what , you better watch what you weld as well , stainless steel gives off Cyanide gas when you weld as well . So any of you guys that want to weld a kitchen sink into the bed better be careful .Theres alot of metals that give off different gass's . Use a resperater when you weld . You'll find under the health and safety act in the US or Canada your suppose to wear one . Im the shop safty man lvl 2 certified . Safety First.
Old 01-30-2011, 10:08 AM
I never knew that, thanks for the tip
Old 01-30-2011, 10:11 AM
DHEM DHEM is offline
Just zip-tie it
yeah anything flammable should be kept far away when welding
SOLD:'05 2wd Ranger xl with the 3.0
MODS-Alpine head unit, throttle cable mod, Black Rock wheels, FX4 lvl II axle swap, pooleo's camo painted bezel and mustang dome, painted/aftermarket headlights/tails fold-a-cover and over 100 hp in stickers
'86 AMC Eagle and '01 Grand Prix GTP
Old 01-30-2011, 05:47 PM
Bird76Mojo Bird76Mojo is offline
troll extraordinaire
Welding stainless steel gives off hexavalent chromium which from my training and understanding, one molecule inhaled can or will eventually lead to cancer basically. Which sucks cuz I used to weld stainless for work without a mask and I sucked in that smoke daily like a flippin crackhead.
http://www.nickelinstitute.org/index.cfm/ci_id/229.htm
GB
2001 Ranger Edge Regular cab, auto 4.0L 4x4 4.10LS
1989 Ranger Regular cab longbed, manual 2.9 4x4
Parts BroncoII's x 3
Old 01-30-2011, 06:29 PM
It's not that it's flammable. It's that it gives off toxic gas that will kill you.
Old 01-30-2011, 08:22 PM
Major376 Major376 is offline
that guy you know kinda
ive never used cleaner, i usually just grind all my metals before welding it.
1985 Ranger 2.3l L4 stock with ghetto exhaust and moon visor gone :/
1986 ranger 4x4 3-5" lift?,30x10.50 pathfinder radials, front bush bumper, 300inline 6 swap (In progress)
Old 02-05-2011, 12:25 PM
racsan racsan is offline
exceding the limits
i thought galvanized was the really bad stuff to weld. used to weld stainless on a regular basis. i worked at a place that among other things made s.s. manifolds for the hinds accord & element. the weld table was always wet from leak testing every manifold then re-welding where it would leak. occasionally someone would spalsh a clear liquid called reactivator onto the table, when you'd start to weld , it would light the whole table on fire. or we'd replace the tungsten bits for the tig torch with sharpened filler rod for the next shift, they would change out a tungsten for a sharpened filler rod, arc on and "pop" the rod would explode inside the tig torch and you needed new guts for it. dont know how many leaky manifold went out the door, you'd get them just good enough and send them on, i know those small leakers will someday be big leaks after all the expansion and contraction cycles.
1993 ranger s/c 4.0 hurst-equipped 5-spd,3.73s ,4x4, milemarker hubs, black grille guard/tube steps,summit rear diff cover with bearing load supports.
"the green machine" (retired-r.i.p.)
'92 reg cab longbed 2.3 "polar express" (stolen)
' 97 reg cab 3.0 auto ($500 project truck)-rolled
'94 2wd longbed 2.3 manual trans
pictures--> https://www.flickr.com/photos/154582...h/37156884305/
Old 02-05-2011, 02:31 PM
Well I might have been wrong as to what metal gives off what gas's and they all do . Being that .... Health and Safety regulation's require all worker's to wear a mask when welding . Not wearing one will cause an accumulative injury . ie: carcinogens .
Old 02-06-2011, 03:19 PM
i think the best thing i did was using an old air pump that came with a moonwalk blowup slide i used to have. i just moved it a good ways away and took some large hose that came from the slide and made a vacuum system for the fumes, that helped alot.
Old 03-04-2011, 06:41 PM
Sorry my mistake , its the sealers and butals that give off cyanide gas , but then so do cigarettes
Old 03-04-2011, 10:19 PM
fstcarkid fstcarkid is offline
meh. shit doesnt worry me. i weld everyday seeings how im in school for it and its going to be my job. lol. really the only time i use a resperator (never) is when galvanized steel is being welded. we usually dont weld that kind of stuff tho. other than that, i breath in all the toxic fumes i can! haha
The difference between stupidity and genius is that genius has it's limits
the definition of insanity doing the same thing over and over again and expecting different results
ya, i can be a dick, dont like it? put a bullet in ur brain
its hard to find good help
"i used to sell, i know pot math"- smakes
Old 03-04-2011, 10:30 PM
OscarMike OscarMike is offline
I hope karma comes and kicks you in the ass for that statement.
Old 03-04-2011, 10:41 PM
lol. ok? i really dont care about it. i know i should, but i just cant convince my self that i need to be worried about it. i got good health insurance! its my job, i take the risk because i love to weld. i understand why some people are scared about the fumes and stuff, but it doesnt scare me all that much. im still young and dumb. but im not dumb enough to spray brake cleaner on a plate i just welded on.
For Sale: Everyone read this!!!! Ranger01 Misc Items 22 08-15-2011 06:21 AM
Everyone Please read this Clinton Off Topic 93 10-15-2010 01:36 PM
5 best sentences you will ever read Stumblefoot Laugh Factory 5 05-03-2010 08:48 PM
Read Before Posting (No really, read this) Tom Introduce Yourself 0 01-24-2010 01:55 PM
Sayin it bc i can(must read) b337y Off Topic 18 12-26-2009 12:02 PM
