Originally Posted by DiabloBlanco
its easy. The hard part is buying it.
NO IT'S NOT. it's not a 3 piece system like your stock stuff. you have to fabricate mounts for the mini fenders that go up behind the wheels/in front of the door. you have to remove your stuck inner fenders running from the cab to the core support/header panels, so you'll have to fabricate those out of some type of metal, and mount everything again such as your fuse block and radiator overflow. don't forget mounting your new headlights, and wiring them up because the plugs are different. you'll also need to make a new upper mount for the radiator, since once again you removed that piece. somewhere on the front you need to make some mounts for the front of the clip as well. everything has to line up too, cuz otherwise the fiberglass will flex and break your clips holding the back of the clip to the mini fenders.
