12-17-2010, 10:01 PM
Frozen Windshield Washer Fluid
Yup, its frozen solid in my girlfriend's '05 Civic. Mine was frozen as well, but mine was low enough to dump De-icing stuff in it to get it to melt, her's on the other hand was all but full, I tried the de-icing stuff in there too but it didnt work.
Anybody have any idea's? Or am I just going to have to stand out there with a hair dryer for 2 hours? It would be ideal if I could park it in a heated garage over night but i dont have that luxury. She's starting to get ornery because I haven't gotten this fixed yet.
12-17-2010, 10:13 PM
Re: Frozen Windshield Washer Fluid
Maybe let the motor run for a bit. If I remember right civics have a small engine Co.apartment so it might warm up quick and melt it
12-17-2010, 10:52 PM
Do not touch the trim!
Probably gonna need the hair dryer or a small electric heater (be real careful of course) or maybe wrap a heating pad around the reservoir (if you can get to it) for a few minutes.
If you can put her off another day... you could duct tape a bunch of hand warmers on there to thaw it out.
'96 XLT, 4.0L, 4x4 Auto, Super Cab, K&N Filter, Dual Exhaust, 200a Alt, Clear Corners, BUGGMAN LED's, Expo Power Seats & Console, LED modded '01 Tails
Need LED's? Send me a PM
LINKS... Click 'em - - -> BUGGMAN PICS - - -BUGGMAN'S YouTube Channel - - -BUGGMAN'S FaceBook
12-18-2010, 12:08 AM
Pour hot water in it to melt the ice then add the de-icing junk
12-18-2010, 12:30 AM
Not really recommended to put water into the washer fluid reservoir. If you have an electric kettle..fill it..boil the water..let it cool maybe a bit and and slowly pour some on the outside with the lid on to keep the water out. Only thing here is the water may quickly freeze as it continues below towards the ground if it's really cold out still..possibly causing other problems. Ideally one of you may know someone who would let you put the Civic in their garage for a while? Another possibility is to remove the container and take it inside if it can be done easily. However you end up doing it get rid of all the old fluid...run the washer dry with some proper fluid in the container..nowhere near filled as the last step. It is worth spending a little bit more on premium -40 fluid..not generic cheap stuff. Same with wipers..there are several new frameless types that work great in the winter. Don't go for the Armour-all(?) ones with 2 yr warranty. I bought them and they chatter..took pressure off more than once..same thing..they advise/warn against using silicone containing fluids..a possible fix..since that will wreck them. Go for almost any except them.
JBA s.s. headers&exhaust, K&N cold air intake, Bosch Iridium Plus 4 plugs, Royal Purple in motor, 5spd & diff.,Superchips programmer, axle girdle. Also have but yet to install KYB Gas-A-Just shocks and Belltech sway bars.
12-18-2010, 05:57 AM
It does have a relatively small engine compartment but we took it to Cabela's and back yesterday and nothing. Thats about 30 minutes each way so it was up to temp.
That hand warmer thing might be a good idea if I can get to the resevoir. For some reason I think its behind the front bumper.
Im not sure that would work quick enough to melt it all the way through?
Thanks for the info. I gotta put it up on ramps to see if I can remove the whole tank.
In the summer, my mom got this Peak Eco stuff. It looks like the normal Peak washer fluid but it has a green label instead of a blue label. Well the shit is terrible. in the summer it would almost foam on your windshield. I thought we used all of it, but i guess not. this is the first time this has ever happened.
12-18-2010, 06:18 AM
that sucks bro
Originally Posted by 03 SB FX4
Originally Posted by 99RangerAlfredo
Originally Posted by cdawall
12-18-2010, 09:43 AM
haha damn ive never even thought about that happening! super bust, im curious as to how you fix this haha
2003 v6 3.0
mods: blinker mod, hella 500ff's behind grille, blacked out grille, k&n intake, throttle body spacer, pioneer headunit and alpine sub w/ JL amp, 3" body lift, flowmaster super 40 dumped, police scanner, Red LED bars under dash
12-18-2010, 09:49 AM
Never experienced this before. Have always used windshield washer fluid that was good down to -35 to -40 deg C year round.
Dave
2010 Ford Ranger FX4
Armaguard sprayed on box liner
Truxedo Low Pro QT tonneau cover
Studded General Altimax Arctic P245/75-16 winter tires on black steelies
12-18-2010, 09:53 AM
I have done it on other cars, dump some hot water in it then add the de-icing fluid so it can break through
12-18-2010, 10:07 AM
My advice is to follow what the others have said. And to add, once you get it thawed, use the rain X peach colored stuff. It has an antifreeze agent in it.
I use this stuff year round, its costly but in winter time when your following traffic it seems like the windows are constantly getting gunked up, and regular fluid freezes as soon as it hit the windsheild.
12-18-2010, 10:12 AM
slut life
Get an electric blanket and stuff it in under ther bumper around the resivour. And put. It on high for several hours.
99 extended cab, 4.0, auto, 33s, 4x4 lifted with some stuff done
98 2wd 2.5, 5 speed, dropped with some stuff done
12-18-2010, 01:44 PM
Check this out. Looks like a pain to remove the tank(s)...
http://wiki.answers.com/Q/How_do_you...2005_Honda_CRV
not impossible though. Isn't there any room to add a little more to the tank(s)? Rubbing alchohol, acetone(I think?) and de-icing stuff from an auto supply chain store if you can at least add an ounce or more may do it. Get it unthawed and run the tank(s) dry..ad a bit of proper winter fluid and run it dry again...then fill it up. Here is an example of some good winter fluid...good for -34F....some are only good for -24F so aren't good enough freeze protection.
http://www.autozone.com/autozone/acc...uestid=6045865
Same store, different brand..still for winter but only good to -25;
http://www.autozone.com/autozone/acc...ntifier=332611
Reason: added a bit more
12-20-2010, 02:05 AM
Drive it down south...Its still "shorts and T-shirt weather" here during the day.
Originally Posted by 05RangerEdge
Nobody won here today but I am pretty sure you just lost.
12-20-2010, 01:15 PM
I tried living in the south, it didnt go too well.
