Old 12-12-2010, 09:43 AM
Default engine help with my expedition
Coming home from an art show yesterday we started to smell gas. Pulled off into a gas station and looked under the truck and gas is pouring out form under it. Right by where the trans bolts to the engine.
The truck ran fine as far as no spitting and sputtering.
I though broken fuel line but thought that would starve the engine for fuel and it would run bad.
is it possible that the fuel rail loose? When I did my COP one of the bolts for the fuel rail had broke. Just wondering if this would casue the last injector to rise out of the head...? How much pressure is normally on the fuel rail, enough to push the injector out...?
Its snowing like a bitch right now, not looking forward to going out to look around, so I thought Id get some advice before venturing out!
Thanks
Old 12-12-2010, 09:50 AM
terryduanemiller terryduanemiller is offline
www.shanewootenband.com
Default Re: engine help with my expedition
fuel leak might be near a fuel rail, gas will puddle on the intake and run off the back, injector O ring, regulator, connection to fuel rail?
MY BUILD THREAD
1999 MAZDA 2500SE, 2.5L 4-clanger, 5 speed, Green n slow. Rangers as daily drivers since 1988.
ASE Certified Mechanic, Builder of Show Destroying Protouring and Classic cars..
Old 12-12-2010, 09:51 AM
2002 2WD Edge 2002 2WD Edge is offline
A little too much for anyone to diagnose from far away man...even my psychotic (she thinks she is 'PSYCHIC'..WRONG!!!! AGAIN!!!) ex-wife to do. You will save time and money if you get your ass out there in the snow and look for the leak. Fuel rail..maybe...my 87 Ranger..2.3L..EFI had a bad leak at one time but a fuel rail leak plus a f***ed injector.
JBA s.s. headers&exhaust, K&N cold air intake, Bosch Iridium Plus 4 plugs, Royal Purple in motor, 5spd & diff.,Superchips programmer, axle girdle. Also have but yet to install KYB Gas-A-Just shocks and Belltech sway bars.
Old 12-12-2010, 10:08 AM
yeah Im getting bundled up now to head out, I think that the injector probably popped up, the leaking was coming from the pass side anyhow. looks like 45 psi is what the fuel rail runs, that might be enough to pop the injector out. I will report back later when/if i get it fixed.
Old 12-12-2010, 10:15 AM
Good luck Jason..hope you find the leak. Muskegan, Michigan..is there a factory/headquarters..Sealed Power there?
Old 12-12-2010, 05:38 PM
So turns out that the fuel rail was the problem. It was up about 1/4" on #4. I tapped it back down and put a 2" C-clamp on the tab where the mount is to hold it down.
I don't think I can get a drill in there to drill it out so this will have to do for now.
2001 Ranger - Engine Knock / Oil Pressure Gauge / Engine Light zomgtehpwn 4-Cylinder Tech 7 01-06-2012 04:27 PM
v6 engine problems rough idle engine boggs casey 3.0 Vulcan Tech 5 04-13-2011 12:53 AM
Need help with my expedition..... pooleo Off Topic 0 11-07-2010 08:34 PM
engine rebuild. or engine swap smsranger Other Engine Tech 13 03-15-2010 08:08 PM
1989 2.3L engine HPvs 2004 2.3L engine HP? Kitsap 4-Cylinder Tech 4 12-02-2009 02:25 PM
