Old 12-09-2010, 05:53 PM
Brianxlt Brianxlt is offline
Ford Rangers
Default Any machinist out there?
Looking to have a photographic panoramic mount made. Basic 3/8” flat stock aluminum drawing to follow.
Lead, Follow or get out of my way!
2010 XLT 4x2 4 dr Super Cab
4.0L SOHC, 5 speed auto, Auto dim mirror w/ home link/remote start,
Chorme Bug gard, Ultragauge, window vents
Next - Bed liner
Suprise, Az - Retired but working
Canon 7D
http://www.flickr.com/photos/brianandlea/
Old 12-12-2010, 11:07 AM
Yrac Yrac is offline
diMwit
Default Re: Any machinist out there?
Don't know what it would cost to machine but I can tell you aluminum is easy to work. You can use common woodworking tools. So if you could build this out of wood, you could probably make it in aluminum too.
'88 STX Super Cab 4x4
2.9 5spd 180,000 miles
Crappy Paint, Worn Parts,
Fix'em as they Break
when Nowhere is Now Here
Old 12-12-2010, 11:19 AM
I could maxhine that but I would need to know the radius of the slot that you want in it. Do you have the material?
Sent from my Droid using Tapatalk
Old 12-13-2010, 03:31 PM
StrokerScamp StrokerScamp is offline
TONS of good 4x4 shops out your way. I would give one of them a ring.
Old 12-13-2010, 03:52 PM
Ford Rangers
I do not have the material. it could be 1/4" stock. the arc would be the same as a 16" oval chinet plate and the inner slot would be the same radius just 1/2" back from the edge.
Next - Bed liner
Canon 7D
Old 12-13-2010, 03:57 PM
if this is something you seriously want to do i could talk to my boss and see if i can get this into the CNC for you. i could get a quote for some material too if need be.
Old 12-13-2010, 04:30 PM
Ford Rangers
thanks for the reply. do you have a guess on $$$.
let me see if I can do it in wood first without getting to thick. I have a pretty heavy camera so I know 1/4" wood will bow a bit I can get exact mesurments that way also.
I will let you know in a week or so.
Next - Bed liner
Canon 7D
Old 12-13-2010, 04:34 PM
ive never really done any side work like this so im not sure what to charge. the aluminum will cost about $20-30 and i would want like $20 to machine it, it would take me about an hour or so. just let me know. if i remember ill get a quote for material tomorrow, it might be cheaper.
Old 12-13-2010, 04:47 PM
Ford Rangers
sounds good $40 - 60 works. I'll let you know what I come up with.
Next - Bed liner
Canon 7D
