02-16-2015, 04:30 PM
Originally Posted by sole
new tools are always good
2003 F-150 Fx4 Loaded-College Commuter & Dual Purpose Rig
2002 Ranger Fx4-Old Truck
02-16-2015, 04:37 PM
Following my dreams
Re: The Offical Vent Thread.
Originally Posted by guell
What do you mean
there is no 4wd manual trans that will fit in my truck for sale anywhere or at any of the local junkyards. and my truck is to short to run a divorced mount t-case
02-16-2015, 05:00 PM
Sure, why not.
Originally Posted by Ordinary Biker
As long as they aren't split elsewhere too...
It has to be frozen where the lines come out of the ground. Apparently they thought it was a good idea to run about 30 feet of line between the ground and the shut off valve. I've scaled every inch of exposed water line and they're all warm. There's no evidence of any of them being frozen. It has to be underground.
2007 XLT Supercab 4X4 V6 4.0L SOHC 5 Speed
285/75/16 Ironman A/T's on M/K Classic Baja's
PA 3" Body Lift - 2" Tbar crank
Thrush Welded 17651 muffler
Blue painted interior - Blue headlight mod
Blinker mod - Throttle cable mod
Originally Posted by Fordzilla80
If a chart said you were straight, but you know you like dick, would you still believe the chart?
02-16-2015, 05:04 PM
are you on city water or well water?
02-16-2015, 05:27 PM
Does it have some bizarre routing from the meter to your house? Here it all has to be under the frost line. So normally frozen pipes are always on your side of their responsibility.
02-16-2015, 05:39 PM
Sure, why not.
Our water is processed from a lake nearby.
As for what is below the surface, I'm not sure. That house was put there sometime after '97. But the pipes come out of the ground at the back of the trailer and stay above ground until the shut off valve which is about directly in the center. It's a 65' house so I've got every bit of 30' above ground. I have 9' of heat tape and insulation coming from the ground side and 12' of heat tape and insulation at the valve. There's about a 6' section in the middle not heat taped.
02-16-2015, 05:47 PM
Ah, that explains it. Sucky set up though eh?
02-16-2015, 05:50 PM
You're not looking hard enough. You're probably not gonna find one locally, but call around to your local junkyards and see if they offer any part locating services. They might be able to find one and have it shipped to their location.
02-17-2015, 09:14 AM
Following my dreams
this may just work...
02-17-2015, 09:30 AM
Mr H....A....P...P....Y👿
Check your messages.
2014 F150 xl 3.7 6 speed auto.
Originally Posted by pk9298
HELL TO THE NO!! Abort abort abort!! That's the first thing to go!!! Ewwwww! I'm not no vampire! I don't enjoy red tea
02-17-2015, 02:21 PM
Sure, why not.
Fucking seriously. Got the lines thawed out just to have a pipe bust.
Ok so the burst isn't too bad. Kinda hard to reach but it's doable. Valve not quite tight enough and is leaking, hopefully that keeps the lines from re freezing overnight so we can replace the busted pipe in the morning. Had to take a day off work but we should finally have running water tomorrow.
02-17-2015, 09:29 PM
Man the girl I was dating 4.5 years ago when I was in high school was a shitty driver. She rear ended somebody with me in the passenger seat going almost 70 mph on an exit ramp. I smashed my knew into the dashboard which had some ******* edge on it (old 90s model Saturn) and that's what hit right I'm my knee. I didn't have any issues back then I felt fine but now my knee is killing me everyday! It pops and hurts like a bitch when I kneel down and especially if I sit on it for a minute then get up it's horrible. I kinda wanna find her and bitch slap her!
2003 xl 2.3 Dohc. Step side with stock 4.10 gears. 235/70 r15 mastercraft avenger gts with 3 inch body lift. Uws black tool box. Aftermarket pioneer head unit. Flow master 40 series wit turn down pipe!
02-18-2015, 12:55 PM
Sure, why not.
Busted another pipe trying to fix the first one. Now going on 5 days without water. I'm at my wits fucking end now.
02-18-2015, 02:33 PM
Fitz
Where are they at? What are you doing to insulate them?
87 extra cab-short bed, SAS D44/9", 5.0 lots of others but that's the basic stuff.
02-18-2015, 02:46 PM
Sure, why not.
They're under the floor but above the insulation. We found out how to get to them which is rather easy. Now we just have to find out if we can pull back the insulation and replace the pipes.
