  #6016
Old 02-15-2015, 07:22 PM
Fitz Fitz is offline
Fitz
Originally Posted by ZacktheBlackRanger View Post
Water lines froze. Pvc pipe going into the house busted. Ball valve won't open. Blew out my only 13mm socket trying to crank torsion bars. Wife hasn't taken her lazy ass of the couch all day. This is why I drink.
Jack it up to take the weight off the tires! Isis mine a couple days ago.
Also I've had to thaw pipes. That shit sucks! I had forgotten to shut the valve off when it was above freezing then the cold front hit and it dropped to neg temps over night with a high of 17 in the day. I was out there with a propane torch thawing the valves so I could shut it off and then had to thaw the whole pipe to get it to drain. Not near as bad as your situation but I hated every second of it.
87 extra cab-short bed, SAS D44/9", 5.0 lots of others but that's the basic stuff.
Old 02-15-2015, 08:42 PM
ZacktheBlackRanger ZacktheBlackRanger is offline
Sure, why not.
It was jacked up. Fucking bolts were that damn tight. Had the same exact problem trying to remove the running board brackets.
2007 XLT Supercab 4X4 V6 4.0L SOHC 5 Speed
285/75/16 Ironman A/T's on M/K Classic Baja's
PA 3" Body Lift - 2" Tbar crank
Thrush Welded 17651 muffler
Blue painted interior - Blue headlight mod
Blinker mod - Throttle cable mod
If a chart said you were straight, but you know you like dick, would you still believe the chart?
Old 02-15-2015, 09:59 PM
02RangerFX4 02RangerFX4 is offline
Lil' Red
Really gotta crank on them. I had to use a breaker bar and a PCV pipe to turn mine.
2002 ford ranger FX4 Off Road | 4.0l v6 | Flowmaster 40 S/I D/O | JBA Headers | Rebello Racing cams | port and polished heads | K&n Drop-in filter | TwinStick | 31 Spline 4.10 Torsen rear diff | Alcoa rims | Sitting on 31's|
Old 02-15-2015, 10:59 PM
Fitz
Oh I see. Did you try putting any oil or PB blaster on it?
Old 02-16-2015, 06:02 AM
floridacracker floridacracker is offline
dogrunner
Originally Posted by 02rangerfx4 View Post
really gotta crank on them. I had to use a breaker bar and a pcv pipe to turn mine.
pvc
2002 Ford Ranger EDGE: 4 inch spindle lift, 2 inch add a leaf, 33x12.5xR15 BFG All Terrrain KO2, Black bullethole steel rims, camo center console mod, diamond plate toolbox, 102 inch cb whip, tinted tails/corners, throttle cable mod, headlight mod, blinker mod, air box mod, Fog light mod.
Old 02-16-2015, 09:44 AM
Sure, why not.
Nope. Didn't realize they would be that tight. I will though once I get some new sockets.
Old 02-16-2015, 11:37 AM
stephen stephen is offline
Default Re: The Offical Vent Thread.
Midterms!
2008 Sport Black 3.0 V6 2WD.
Build Thread
Old 02-16-2015, 12:01 PM
Sure, why not.
Well now I'm in a pickle. Found out my valve is definitely bad. I have the replacement valve, but can't shut the main valve off. Don't have a big enough pair of pliers. My neighboring grandpa does, but he's not home, and I'm having no luck calling a plumber. I guess my options are waiting it out, or heading the the hardware store.
Old 02-16-2015, 12:50 PM
sole sole is offline
new tools are always good
Black 2008 ranger sport 4.0 SOHC SAS'd and converted to 4x4 riding on a Dana 50 up front and a sterling 10.50 in the rear regeared with 5.13's, mickey thompson classic 3's rapped in 37x12.50 maxxis creepy crawlers
Old 02-16-2015, 01:30 PM
Bigcat1911 Bigcat1911 is offline
Following my dreams
I just want to make my truck 4wd but theres no transmission out there that will do it
2005 EDGE 3.0 V6 5-Speed, Modest Lift and Tires, 4x2, 4.10 LSD, Regular Cab
Color: Labatt Blue Name: Trixie
Build Thread:
http://www.fordrangerforum.com/proje...er-trixie.html
Old 02-16-2015, 02:21 PM
guell guell is offline
What do you mean
Old 02-16-2015, 02:47 PM
You're obviously not looking hard enough.
Old 02-16-2015, 02:59 PM
Sure, why not.
It never ends. Got the valve replaced, but STILL don't have water because it seems the the lines froze up somewhere else.
Old 02-16-2015, 03:30 PM
Bitzy Bitzy is offline
13' Focus
I hate how people feel like they can drive with led pods on. Its not like it says "Off road use only" on the box or anything. I would flash my light bar at them but I don't want to piss of the people behind them.
1999 XLT 4x4 3.0 Flareside
Off Road package, Towing package, 4.10's, 129k miles
Mildly Lifted
My Build
SOLD
Old 02-16-2015, 04:13 PM
As long as they aren't split elsewhere too...
*Offical* What did you get for X-Mas Thread. RangerNDog Off Topic 67 01-04-2011 07:18 AM
Want to Buy: AC/Heat Vent IndianScout Interior Parts 4 11-09-2010 01:25 PM
Air Vent LED's RedPowerRanger Interior Tech 8 07-23-2010 11:04 PM
hurst vent/fix mossyoak03 Drivetrain Tech 1 06-18-2010 03:54 PM
ac vent pmac03 Interior Tech 7 12-28-2009 09:48 AM
