Re: Way off Ranger topic.
General rule of thumb is that if you replace 1 it is best to replace both. That is since when one the calipers has a problem it messes up the other one, such as in many cases if one caliper is sticking it can be the other side that has the problem. However, if neither is bad you should be ok to replace just one.
'94 Single Cab 4cyl 5spd
Still in the parts collecting stage for a 2.3t swap
Old:
1999 F150 ext cab 4.6 4x4--Totalled
1995 F250 ext cab long bed 7.3 4x4--Sold
1999 Ranger ext cab 3.0 2wd--Sold
