  #1246
Old 04-24-2013, 12:12 PM
11Sport 11Sport is offline
Originally Posted by Redneckstone View Post
From what I gather its a dual action/single action pistol. First pull is dual action then it's single action after that. So trigger shouldn't reset fully. Dd you try shooting it when after first pull?
I guess I should have thought about that. I assumed he had know when his pistol would be double/single action.
2011 Ford Ranger Sport Ext. Cab 2WD
4.0L SOHC - K&N Air Charger - Gibson Dual Exhaust - Grille Guard
Old 04-24-2013, 01:23 PM
Default Re: Your Gun Pics, Post Em Up!
Yes I did, nothing happened. The hammer wasn't ****ed after I fired the first round
Edit: lol it blanked out C*ck
Old 04-24-2013, 01:26 PM
Sounds like the sear isn't engaging the hammer. Can you rack the slide and have the hammer stay back?
Old 04-24-2013, 01:30 PM
Yes, it does do that
Well wtf, its working now with no bullets in it
Old 04-24-2013, 01:32 PM
OK see link to attached post on another forum
http://www.waltherforums.com/forum/f...ay-****ed.html
It sounds like the recoil spring is either to strong and not allowing the slide to go all the way back thus not c0cking the hammer, or the rounds are not stong enough to do the same thing, or both.
Old 04-24-2013, 01:33 PM
It sounds like the recoil spring is either to strong and not allowing the slide to go all the way back thus c0cking the hammer, or the rounds are not stong enough to do the same thing, or both.
you really think its the ammo? I got a bulk box of the Remington 115gr UMC's
Old 04-24-2013, 01:34 PM
Edit: disregard this post
Old 04-24-2013, 01:37 PM
this is what im thinking too
Old 04-24-2013, 01:39 PM
It may be the recoil spring that is to strong, however check one more thing. Rack the slide and c0ck the hammer back. Then press forward on the hammer to see if it will release and move forward. (It shouldn't)
Old 04-24-2013, 01:40 PM
Ok. That link didn't work btw. But you guys are just saying that its either the spring or the ammo or potentially both
Old 04-24-2013, 01:42 PM
Link won't work because c0ck is blocked out of the address by FRF editor. Haha.
Yes. Also do the test that I said above.
Old 04-24-2013, 01:46 PM
If it chambers another round, then it can't be that the recoil spring or ammo is too weak.
Old 04-24-2013, 01:50 PM
I tried your test and I can't push it forward like you said. And yes, it does chamber another round.
This may be a dumb question, but there isn't a difference between " 9mm parabellum " and 9mm luger " right?
Old 04-24-2013, 01:51 PM
Well if it chambers another round that means that it can't be that the recoil spring is too sting, or the ammo too weak. Could be that it is too weak in not allowing the slide to be pushed all the way back forward after the shot.
Old 04-24-2013, 01:52 PM
A gun can chamber a round but still not lock the hammer back. This is caused by the spring not allowing the slide to come all the way back or the ammo not having the pressure to push the slide back far enough.
Post pics of vehicle you've seen around! dixie_boysles Vehicle Snapshots 12827 09-13-2015 05:58 AM
Gold trucks post you pics Brodie_laj Vehicle Snapshots 49 11-15-2012 03:40 PM
Post your seat cover pics? Mike Interior Tech 5 12-11-2010 11:57 AM
I support the second amendment. (gun pics) 01_ranger_4x4 Off Topic 16 04-23-2010 03:46 AM
thought I would post a few pics of the truck here BILTRITE BULLIES Vehicle Snapshots 21 01-01-2010 08:45 AM
