Old 09-27-2010, 11:49 AM
dixie_boysles dixie_boysles is offline
5.Oh All the way
Send a message via Yahoo to dixie_boysles
Default Is this wiring diagram correct for my boat?
I drew this up real quick to figure out how to wire up my boat. Sorry if it is not politically correct, but you get the general idea.
Basically all the ground wires will merge to one bolt connector to the battery and the hot wire will go to fuse panel and distribute out to accessories.
2014 F150 SuperCrew XLT 4x4
275/65/17 Falken Wildpeak AT3W | Shorty Antenna | Tinted Windows | ProClip Phone Mount |5.0 v8 |Tow Package | Oxford White
Sold/Totaled: 2006 Ranger XLT 2D SuperCap 4x4 Torch Red
15x8 Pacer 164P Polished Wheels | 31x10.50 BFG ATs | Level II Tow Hooks | FX4 Red Insert Seats
Tinted Windows | 6000K HIDs | Kobalt Low Profile Toolbox | Pioneer Speakers
Old 09-27-2010, 11:51 AM
Default Re: Is this wiring diagram correct for my boat?
I think you need a few more zigs and zags but ... yeah that works
Old 09-27-2010, 11:55 AM
5.Oh All the way
what ya mean?...lol
Old 09-27-2010, 12:06 PM
NOOOOOO!!!!! No no no. That will ignite. Standby while i type more.
Old 09-27-2010, 12:12 PM
You have this all bassackwards. The switch needs to actually switch the power to the devices. You have the switches shorting out the entire system. Red wire from fuse panel, into the switch, out of the switch, to the device. Black wire direct to the device. If the switches are lighted, then the switch will have a ground as well.
The flow to each device should look liket this:
(+ Frome Fuse)--------->[Switch]>-------- Red wire on nav light
(- From Batt)----------------------------- Black wire on nav light
(+ Frome Fuse)--------->[Switch]>-------- Red wire on anchor light
(- From Batt)----------------------------- Black wire on anchor light
(+ Frome Fuse)--------->[Switch]>------- Red wire on deck lights
(- From Batt)----------------------------- Black wire on deck lights
(+ Frome Fuse)---------------------------> Red wire on fishfinder
(- From Batt)-----------------------------> Black wire on fishfinder
Old 09-27-2010, 12:13 PM
5.Oh All the way
ok
Old 09-27-2010, 12:16 PM
5.Oh All the way
haha, you made a pun, that is the name of my boat see:
http://www.fordrangerforum.com/proje...-boat-log.html
now back to seriosness, thanks for the write up!
Old 09-27-2010, 12:21 PM
5.Oh All the way
only thing is, i want the two courtesy lights on one circuit and the two navigation lights on one circuit.
Old 09-27-2010, 12:30 PM
5.Oh All the way
fill this out for me matt:
Old 09-27-2010, 12:39 PM
Alon Alon is offline
2AM Fabrication
Send a message via AIM to Alon
The switch should be interrupting the red wire, not connecting the red and black. IF you connected the red and black... you will have a fire.
All ground wires on devices can go to a common ground or back to the battery.
All power wires need to be interrupted before the device.
}---------> 2:AM Website <----------> 2:AM Facebook<---------{
Old 09-27-2010, 12:47 PM
5.Oh All the way
gotcha, thanks ya'll!!!! i knew i could count on ya.
now for fuses. Drew told me but i forgot to write them down. what size fuses on these things
Old 09-27-2010, 01:13 PM
As you can see, my artistic abilities are unmatched. Normally I would do this on Visio but this does get the job done.
For the fuses, 5 amp slow-blow fuses on the nav lights and anchor light. The deck lights, a 10 amp slow blow should be fine. Whatever the fishfinder is spec'd at, probably more like 10amp fast acting. Make sure you seal all your connections with silicone.
Old 09-27-2010, 05:54 PM
5.Oh All the way
thanks matt, one change though, i want the bow and stern light on two switches, one in the back and one in the front, so no matter if im in the front or back, i can turn them on. is this possible?
I see you have a seperate switch for the bow and stern lights. lets link the two.
Old 09-27-2010, 05:57 PM
You totally lost me. You want to operate the lights from two different places??
Old 09-27-2010, 06:10 PM
5.Oh All the way
yes. on most bass boats, you have the swithces at the console and also at the front of the boat near the fishfinder and trolling motor so that no matter where you are you have access to the lights, bilge pump and livewell
AUX input wiring diagram tahenke Audio / Video 17 02-23-2014 03:21 PM
Amplifier Wiring Diagram STL Audio / Video 11 02-06-2014 07:27 PM
transmission wiring diagram dtownboy_Erk Drivetrain Tech 0 06-15-2010 08:49 PM
T-case Wiring Diagram JoeShmo Electrical Tech 1 04-13-2010 01:39 PM
Radio Bezel Wiring diagram? Mike Interior Tech 4 03-27-2010 12:34 PM
