09-15-2015, 05:02 PM
Explorer 5.0 swap towing
I want to swap the explorer 5.0 next year I was wondering if anyone has experienced a increase in the truck handling loads better?
2001 Xl 4x4 4.0 4 door
09-15-2015, 05:37 PM
it's just more power. Truck will handle the same as nothing has changed suspension wise
2000 Ford Ranger XLT 2WD ~ Work-In-Progress: 5.0 V8, M5R2 5 Speed, 4" Suspension Lift, 3" Body Lift, 33" BFG's, Bilstein 5100's, Comp Cams XE258HR-12, 24# Injectors, Torque Monster Headers, Flowmaster 70 Series,
1987 Ford F-150 Lariat 302 ~ Decommissioned
2006 Honda Civic LX 1.6 ~ Totaled
2011 Acura TSX K24 Base ~ Daily Driver, Supercharged 10PSI, 310whp 241lb/ft
09-15-2015, 06:06 PM
Re: Explorer 5.0 swap towing
Still will have the same weak link in the brakes.
2013 Ford Focus SE hatch - My daily driver
2018 Chevy Equinox diesel- Wife's
2001 Ford Ranger XLT 4x4 4.0 Supercab Off-Road Stepside - Bunch of stuff.
09-15-2015, 06:16 PM
Will actually be harder on the brakes with the extra weight. Might add rear discs and use performance discs and pads.
09-15-2015, 08:36 PM
I'm aware of suspension upgrades and rear discs I'm just more concerned about the motor
09-16-2015, 01:05 AM
You are concerned it isn't as strong as the 4.0 ?
09-16-2015, 05:42 AM
Basically
09-16-2015, 06:09 AM
F150/ranger owner
Lol
1994 Ford Ranger XLT 2wd 3.SLOW! Bauce Edition No cats ftw Super 44 Dumped
Mods:Build Thread
Originally Posted by Devin-20
There aint nothing more manly then a purple truck..
Originally Posted by Spidey2011
Oh. My. God.
Two purples..... -_-
Originally Posted by robertmcclure
matthewticus purpliticus
09-16-2015, 06:11 AM
Seems like a really simple way to figure this out.
Look up explorer 5.0 towing capacity.
Problem solved.
Not a F150 sellout? Click HERE
adamantium tamponicus!
09-16-2015, 06:45 AM
Basically
EFI 5.0 V8 vs EFI 4.0 V6.....that is hard to figure out which has more pulling power.
09-16-2015, 11:37 AM
Just saying ?
09-17-2015, 11:48 AM
Originally Posted by RagerTom
Seems like a really simple way to figure this out. Look up explorer 5.0 towing capacity. Problem solved.
The towing would be different cause it's a truck vs a suv
I really only want comments if u have a 5.0 swap and you tow things
09-17-2015, 12:01 PM
The towing would be different cause it's a truck vs a suv ---------- I really only want comments if u have a 5.0 swap and you tow things
it will obviously pull faster. Getting to speed, engine works less, a lot more torque... But tow ratings aren't just based off horsepower and torque. There's also frame flex, suspension spring rates, vehicle weight, and most importantly stopping power. And unless you can upgrade all of those, the difference in towing is negligible
09-17-2015, 12:03 PM
-__-
hey shut up. You don't tow anything. And your 5.0 isn't running yet.
09-17-2015, 12:10 PM
-__- ---------- hey shut up. You don't tow anything. And your 5.0 isn't running yet.
hey he is right about truck vs suv. Leafs are over on the ranger vs under on the explorer. But the other factors still apply
I'm getting there! It's manual so I won't be towing too much, but enough to get jetskis to the water!
