06-12-2015, 01:32 PM
Cabinet Repair help
Hey guys sooo kong story short I went to go pull on a cabinet door and the screws all gave up holding it on... I don't know how im gonna reseat them anyone have any ideas?
2002 ford ranger 4.0 SOHC steppie auto|airbox mod|throttle cable mod|flowmaster super 44 side exhaust|4X4 off road
coming soon:|halo lights| and interior work!
06-12-2015, 02:12 PM
Re: Cabinet Repair help
move the hinge down on the door about 1/2", drill new pilot holes about 1/4 the length of the screws, and you should be good to go.
06-12-2015, 02:41 PM
Thanks!
06-12-2015, 04:53 PM
Stick some little pieces of wood (like toothpicks) in the existing holes to tighten the hole,
Then run the screws back in.
06-12-2015, 06:54 PM
Last one to let you down
You can also use the plastic wall Anchors that are used on drywall.
The problem with moving the hinge, that hinge require you to drill out the door for the spring loaded part to go in...
i would use wood, or anchors as suggested. or JB weld that bitch on
06-12-2015, 09:43 PM
I tried the first posters idea and the screws wouldn't seat... Tried this after a neighbor showed me and it worked great! We put gorilla glue on the ends of the toothpicks to keep em in there too
06-14-2015, 04:09 PM
sorry man.... fuckin particle board crap, lol
06-15-2015, 09:08 AM
Yup. Use ordinary carpentry glue (or common white glue) slathered onto a chunk of wood that you can tightly wangle into the hole. Fill the holes completely & tightly, with wood. Loose fit won't do. I usually use a hammer to tap the wood into the holes to get a tight fit. Leave excess wood sticking out, for now, until glue dries. Let glue dry for a few hours, then snip off any excess sticking out & sand it smooth. Toothpicks are OK for tiny screw holes. Whittle larger pieces for larger holes. This works great in any wood, even particle board. Good as new!
1997 4x4 Mazda B4000 SE, Ext.Cab
06-16-2015, 06:28 PM
Lol yea it shredded when I pulled the door off lol particle board is something else
