Old 01-11-2015, 03:14 PM
1991SuperCabXLT 1991SuperCabXLT is offline
They Call me Danger
Default Welding Advice
I bought myself a mig welder not too long ago and now I am in the learning process. I now need some advice as to what I am doing right or wrong. Bare in mind that I'm just starting.This was done using a Hobart 190 mig welder using .030 or .035 (can't remember which) flux core wire. Any help is appreciated.
Luke
1991 4.0 4x4
3in body lift, 4in rough country suspension lift
33x12.50r15 duratracs
Old 01-11-2015, 04:14 PM
JFortner5 JFortner5 is offline
Vulcan Junky
I'm a self taught welder, so take what I say with a grain of salt. It looks pretty good to me for just starting out.
I always found it easier to practice welding to pieces together instead of just making a bead. If you can find some 1/4" thick scrap steel and try welding it together that may help, it did me anyway.
I've always done MIG and not flux core but I do know that using gas makes a prettier weld.
Again I'm no expert but it sure is fun to weld every once in a while.
1999 GMC Sierra SLE
ECSB 2wd, 4.8L, 4l60e, 3.42, 50k miles
2002 Ranger Edge
RCSB 2wd, 3.0L, 5 speed, 4.10 , 140k miles
Old 01-11-2015, 04:51 PM
rachit rachit is offline
B4000
Default Re: Welding Advice
Get good penetration with no undercut and keep a smooth steady hand. Keep your speed consistent try not to go too fast or too slow, all it takes is practice. MIG or flux core is pretty easy but with the flux core you might have to go a little slower to help it burn in more maybe do a little weave too. Practice and you'll find out you can do a lot with your little machine, I have a small 90 amp flux core welder and I've built and fixed a lot of stuff with it.
Slightly improved
4.0 5 speed manual, 31 spline torsen, skid plates, brush guard, LT265/75/16, Explorer OHC and more
Old 01-11-2015, 05:33 PM
johnday johnday is offline
Useless olde guy
Looks like you started out too fast, then slowed down too much. In other words, the first part of the bead is cold, the rest is hot with a lot of undercut.
Practice your butt off, it'll hit you sooner or later. The cold bead has little penetration, not good. The hot part likely has good penetration, but just not pretty. Get to where you can lay down a good bead, then try some butt welds.
Keep trying, you'll do it.
'04 Edge, Scab/flareside, 2wd, 3.0, 5 speed, 4:10 open. Billet grille, Raceline Raptor black wheels, 265/75/16 DuraTracs. Tbar crank, AAL. Fox shocks, Thrush welded SI/DO swept back side exit. Morimoto projectors, '06 tails and power mirrors. LEDs all the way around. Blacked out fender badge. Access Limited rollup tonneau. 5% tint on back three windows. Airbox mod, FWIW. And a Border Collie that likes it too!!
Old 01-11-2015, 06:43 PM
MdubG MdubG is offline
Here we go again!
Always, amd i mean ALWAYS watch your puddle. Watch how it spreads and always have the puddle in view...if you cant see the puddle, you cant accurately weld. Just like the others said slow down. If you start burning through turn you heat down.
2003 Red Danger Ranger extended cab
3.0L V6 2WD w/ Overdrive
Pioneer Radio
Sound Ordinance Amp
Diamond Audio 10" Sub
Air Box Mod
Old 01-12-2015, 06:46 AM
-Ray- -Ray- is offline
Ford Pickup
I bought a Lincoln Mig Power 140 a year or 2 ago.
I had no experience welding. I was a grinder not a welder.
I found this site looking for help. I found great advice and my welds have improved 100 percent.
Jody's Youtube videos cover Tig, Mig, and stick welding.
2012 Chevy Equinox
2011 Ford Fiesta DD
2008 Pontiac G8 GT
2007 Pontiac Solstice
1999 Ford Ranger 2.5 L manual
Old 01-12-2015, 07:38 AM
They Call me Danger
Thanks for the help guys. I will be getting a gas tank soon.
Luke
1991 4.0 4x4
Old 01-12-2015, 07:55 AM
casey.mikl casey.mikl is offline
Sub'd. Also just got a mig welder. I have a snapon MM250SL it's a 185 amp. Got an 80lb bottle for it too. Gonna teach myself and this thread will help.
1997 B2300 reg cab 2.3 Lima, 15x8.5 Mickey Thompson classic 2, 31x10.50 cooper discover at3, 7.5 open 4.10 rear, dynomax super turbo catback, alpine iva-w200 w/ nav, kicker 6x8s, alpine type R 8, alpine 250W mono amp, power bass 400.4, tool box & camper shell, compustar alarm/remote start.
1956 Ford F100 rust bucket with big plans!
Welding help Greenranger01 Fabrication and Tool Tech 31 10-07-2014 11:41 AM
differential welding 95 ranger 3.0 Project Logs 5 08-11-2014 03:44 PM
Help needed for welding. Mike69 Exterior Tech 17 11-12-2013 08:40 PM
Welding. Baller Off Topic 22 10-14-2012 06:42 AM
welding needed scottgmacjr Northeastern Region 2 08-12-2012 06:26 PM
