Today was an awesome day. I got my order in from WestCoast Shaving supplies and I also got another epic shave, but it was with the safety razor and
not the Feather Artist SS non folding Japanese straight razor. It's still early yet but it did pretty good in my trouble spots:
These guys are awesome. If you ever need any shaving stuff then these guys is who you need to talk to. And they're affordable as well:
Here's what I got:
Here's the straight razor/shavette I ordered:
^ It's pretty cool and I consider it a hybrid type of razor that can be used like a safety razor with the correct blade and the old Noxema trick
(rinse with hot water and apply Noxema between passes for an ultra slick surface). Here's the entire length of the shavette:
^ It's got a really comfortable handle with an excellent grip that I found very easy to use. Here's a closer look at the head of the shavette (blade holder) :
^ It's got a rolled edge which takes the pressure off of the blade and skin which provides a close and smooth shave with the right blade. Speaking of blades,
don't get these because they're way too sharp and they snag really bad:
^ These need the alot of glide to get a comfortable shave. In fact alot more than normal:
^ The razor comes apart really easy for cleaning and blade removal is a breeze. This stuff here is awesome and performs really good:
^ The scent this stuff has is a various mixture of various hardwoods. After shaving you run this block under cold water to seal off your pores. Unfortunately it's not as good as the stytic pens that are on the market at a much cheaper price:
^ It's decent but like I said there's better stuff out there. I added this stuff to my post shaving routine to help aid in healing if I get too close of a shave and get a touch of razor burn:
^ this helped out alot with razor burn and it was very affordable compared to the shaving oils that are on the market.
