01-13-2014, 09:48 AM
impact wrench suggestions!
I want to buy a 1/2" pneumatic impact wrench! Does anyone have any suggestions?
Ford Ranger, 1998, Reg Cab, 2WD, 5 speed, 4 cylinder, 140k
01-13-2014, 10:40 AM
Ingersoll rand if you looking for quality. Otherwise harbor freight earthquakes aren't bad for the price.
98 Mazda B4000 Ext. Cab 4.0 4x4
01-13-2014, 11:23 AM
Re: impact wrench suggestions!
Love my Snap-On. Can't go wrong with going with a good brand. I can't tell you the model number or it's torque numbers, but she's worked GREAT for me for more than 5 years now.
'01 XLT disguised as a '03 Fx4 Level II.
01-13-2014, 11:53 AM
YEE YEE!
This question all comes down to how much you wanna spend. Are u just using it at home or are you in a shop looking to add to your tool collection of thing u use daily.
2004 Ford Ranger XLT FX4 Level II : Weekend Driver (Oct. 2013 TOTM)
2003 Ford Ranger EDGE 4x4 : Daily Driver
1991 Ford Ranger XLT 4x4 Small Block Stroker : On going project
1994 Ford F350 Turbo Diesel 4x4, Short Bed Single Cab : On going project
1967 Ford Mustang Coupe : Restored to original
01-13-2014, 12:02 PM
and AnythingWillHappen
I'm with the guy above I would go with Ingersoll rand
http://www.amazon.com/Ingersoll-236-2-Inch-Impact-Wrench/dp/B0000AX9R2/ref=sr_1_3?ie=UTF8&qid=1389639677&sr=8-3&keywords=ingersoll+rand+1%2F2+air+impact
http://www.amazon.com/Ingersoll-Rand-2130-2-Inch-Heavy-Duty-Impact/dp/B0002UNR6W/ref=sr_1_4?ie=UTF8&qid=1389639644&sr=8-4&keywords=ingersoll+rand+1%2F2+air+impact
http://www.amazon.com/Ingersoll-Rand-2135QTIMAX-2-Inch-Titanium-Impactool/dp/B000WMR8H4/ref=sr_1_5?ie=UTF8&qid=1389639666&sr=8-5&keywords=ingersoll+rand+1%2F2+air+impact
Just depends on How much you want to spend
snap-on is good too
2010 Fx4 F150
2003 Ford SVT Cobra
2000 Ford Ranger XLT 4x4 Offroad =====SOLD
5.0 V8 with L/S 4.10's and a lot of other crap
01-13-2014, 12:06 PM
Ingersoll rand are top notch if you have a compressor that can handle the CFM they require.
2003 fx4 levelII 4.0 5speed manual t-case 4.10 gears with eaton E locker in the back.
2001 mountaineer 5.0 awd loaded and stock
2004 chevy 3500 cclb dually duramax
01-13-2014, 01:56 PM
thanks for the great info. this one from harbor freight is $97. it got good reviews. http://www.harborfreight.com/air-too...nch-68424.html I would just be using it sparingly as a hobbyist mechanic. if I could get one for $100 that was not a piece of crap that would be great. Anythingcanhappen posted an Ingersoll rand for $89 that had a toque of 440 lbs. I wonder what torque I would need to remove a crank bolt? thanks again.
01-13-2014, 02:24 PM
YEE YEE!
I wouldn't suggest taking and engine apart with an impact anyways. not a good idea especially a 1/2 inch drive I would use a 3/8th or do it by hand. Maybe I'm just cautious and if im taking main caps off of a crank I would much rather not break a bolt off in the block.
01-13-2014, 02:33 PM
x2
2010 Fx4 F150
2003 Ford SVT Cobra
01-13-2014, 02:36 PM
I love my mac impact..900 breakaway and 750 forward iirc
01-13-2014, 02:38 PM
I actually don't do much engine work. I do have some timing belts to do and it looks like an impact wrench would help removing the crank bolt, etc. Thoughts?
01-13-2014, 02:39 PM
Oh yea that an impact is probably the only way. They are tight as hell
01-13-2014, 02:40 PM
YEE YEE!
I just am a hand tool guy in my shop I get very leery on putting a lot of torque on something you don't know its gonna move so usually I break stuff lose by hand then just use an impact to zip it out and in that case a 3/8ths gun will do fine
01-13-2014, 03:04 PM
If I were you I would buy these
http://www.homedepot.com/b/Makita/N-5yc1vZyg
The makita impact driver or any cordless impact driver for that matter is great
Now that I have one I reach for that over my regular air impact gun almost every time.
jmo
2010 Fx4 F150
2003 Ford SVT Cobra
01-13-2014, 03:12 PM
Ford yeah!
Check out Pawn shops. I have a Husky brand 3/8th gun it does what I need it to do. I thought I was going to use it more when I bought it. I use mine for motor mounts after I break them loose by hand.
If you choose to use it when loosening the bolt on a lower pulley, or related bolts. I recommend using extreme caution with the process. You are asking for trouble IMO specifically if it is your first time working with a buddies, or a customers car. You could buy some decent breaker bars, and save some pesos. For ratcheting boxed end wrenches....
2003 Ford Ranger Edge ext. cab 3.0 V6, M50D, Rwd, 4.10 open, Tow pkg. Sonic Blue,Fab-tech 3" spindles AAL +3" blocks out back. Buggman LEDS, 15x7 Pro-comp 52's, rolls on 32x11.50xR15 Cooper Discoverer STT, tonneau cover, Mini mask, Pintle hook, AEM- Dry-flow airfilter, Flashpaq 1865, Flowmaster 40, 10% tint, Kenwood deck and speakers, cheap seatcovers, Alpine S-10" MRP-M 350 MRP-F 300
